RE: Neu Schweizer anlage
#1 von carleso123 , 28.04.2017 10:58
Guten Morgen.
Es ist mein erster Beitrag im Forum.
Ich werde auf Englisch schreiben, wenn Sie kein Problem haben.
I recently started with my layout. Scale H0, material Märklin, digital C gleis.
Epoche VI - V
Schweizer SBB Material.
I´d like to reproduce a Station from the German - Swiss area prior to Gotthard tunnel. (Something like Göschenen) with the reduced space I have.
The dimensions of the layout : 4. 70 Mts. x 1. 70 mts L- Form.
Three (3) levels. (Main station visible on the top.
I hope you all help me during all this construction process..
Many Thanks.
I want to attach the pictures of the progress.
Please, could some one tell me how to do it ?
Many thanks again.
carleso123
carleso123
Registriert am: 14.02.2013
#2 von Mountainking , 28.04.2017 13:03
Here is the Answer to most asked Questions from Starters in this Forum:
viewtopic.php?f=30&t=30285
I use aboad. You can load your pics in abload and customize them. Like sizing or Sepia-effects or else. You can Cluster them. And, that's what you asked for, link them in. if you take Pictures with you mobilephone you can use the abload-App. It's comfy.
And now we like to see, how little Switzerland is growing.
Rainer
Ei, warum dann ned' ?!
viewtopic.php?f=64&t=119946
Mountainking
Mountainking
Registriert am: 27.11.2014
#3 von carleso123 , 28.04.2017 16:20
Hi Mountainking !
Many thanks for your comments
Finally it seems I reach to attach the pictures.
Inspection hole West Side and detail of motor switch access.
More details.
Detail of the main schattenbahnhof versus East
Hope this may give an idea of what I´m working with at this time.
Waiting for the S88 modules and Switch decoders ....
Neue bilder von heute...
New material arrived.. M83 Decoders and S88 Modules.
Let´s start to isolate track sections !!!
This will take longer..there are many sections to isolate.
Three(3) kontkt gleis is the right number for each section ?
I have intention to manage the layout using the CS2 (60215) and the PC (Win Digipet)
Have a nice weekend!
carleso123
carleso123
#4 von carleso123 , 01.05.2017 20:09
Good afternoon everyone.
I'm still working.
Today I have modified the switch motors .
I have read several times that it is better to make this bridge between contacts to prevent the coils from burning.
I will do this with all motors, and then test them to confirm right operation.
soldering the bridge between contacts in switch 1
soldering the bridge between contacts in switch 2
Applying some electrical adhesive tape to isolate
Re assembly of the metalic cover
Repeat process with all motors
Hope all them will workk fine after this !!
MFG !
carleso123
carleso123
#5 von swisstrain , 16.10.2017 00:29
Sieht interessant aus. Ich mache auch eine Märklinanlage mit C-Gleis, Thema Schweiz, Oberleitung mit angelegten Bügeln. Zur Betriebssicherheit, Tipps und Tricks habe ich in einem eigenen Thread gemacht.
Ich würde mich über einen Erfahrungsaustausch mit dir freuen!
viewtopic.php?f=29&t=147425&hilit=anf%C3%A4nger
Lieber Gruss
Mein bescheidener Beitrag
viewtopic.php?f=64&t=76150
Tipps für Betriebssicherheit auf dem Märklin C-Gleis
Tipps vom Erfahrenen für Betriebssicherheit auf Märklin C-Gleis
swisstrain
swisstrain
Registriert am: 21.11.2010
#6 von thagu , 21.10.2017 18:31
Hi Carles (I missed your Name...?)
Nice setup, looks even pretty similar to my recently startet Project, but with C-Tracks! Looks really neat!
Will follow
Regards,
Guido
Redbox mit internem Booster, PC und TAMS Weichedecoder und Rückmelder. Märklin Rollmaterial, Mittelleiter C- und K-Gleis, ESU Lopi 4.0 M4
Anlagenplanung
Anlagenbau
thagu
thagu
Registriert am: 26.12.2016
Gleise Märklin K-Gleis
Steuerung Vollautomatisch, Rocrail, Redbox
#7 von carleso123 , 21.10.2017 18:43
Hi Guido.
Nice to hear from You !!
Many thanks for your comment!
Yes,I I have all c tracks prepared for the complete layout, but finally I decided to use K track on the upper level where the main station will be, and other visible parts.
I realized that you progressed with the cabling.
I´had no progress during the last three months because I´m working out of the country, but believe that I really want to come back to push it again !
I will need some help on the electric part with the decoders. S88 and S88 Link.
I will follow your job with enthusiasm !
To give you an idea the layout would be similar to another one that you can follow on this forum and that is really awesome URI Anlage.
Many thanks to contact me .
With best regards.
Carles.
carleso123
carleso123
#8 von carleso123 , 31.10.2017 10:52
Dear friends of the forum ..
I have been thinking for many days, the possibility of replacing all the C track type by type K.
After analyzing the possibilities, I think that because of the space and dimensions of the layout, the K-way allows me more possibilities with radios and transitions.
The hidden station at the same time could accommodate more trains ..
Is this correct ?
What do you think ?
Thank you very much for your comments.
Best regards.
Carles.
carleso123
carleso123
#9 von swisstrain , 01.11.2017 15:51
Hello
The gemoetrie of the K-track could be better for you.
But on the technical Level, the C-track is much more up to date, your layout will work smother with c-track.
Den Rest muss ich auf Deutsch sagen...
Der Betrieb auf dem C-Gleis ist erfahrungsgemäss sicherer:
- Weniger Probleme mit Entgleisungen
- Bessere Kontaktsicherheit für Mittelschleifer bei Weichen / Kreuzungen
Für die Sektionen der Anlage, die mit einer fixen Geometrie aufgebaut werden, würde ich sicherlich das C-Gleis empfehlen.
Für die Sektionen mit Flexgleisen kannst Du ja das Übergangsgleis von C zu K benutzen und diese Abschnitte mit dem Flexgleis aus dem K-Sortiment gestalten.
lg
alex
swisstrain
swisstrain
#10 von carleso123 , 01.11.2017 16:27
Good afternoon Alex.
Thank you very much for your response.
Although I agree with your reasoning, I still see a problem in the permanent space of the hidden station, where K Gleis would have more options (in terms of capacity).
Best regards.
Carles.
carleso123
carleso123
#11 von swisstrain , 02.11.2017 14:08
But why you have more capacity? I thought that K-Gleis Switch has the same radius as c-gleis Switch = R2, right?
swisstrain
swisstrain
#12 von carleso123 , 02.11.2017 14:47
Hello again, and thaks to reply.
According to my trackplan on Wintrack, in the same width of 85 cm, there is only space for R1 and R2 if you use C gleis.
In the same space, tou can use three (3) radius with K gleis R1, R2 and R3.
Also in this space, you can install more parallel Straight track section, because of the difference of width between K gleis and C gleis that has the ballast.
Is this correct ?
Many thanks.
With Best Regards.
Carles.
carleso123
carleso123
#13 von carleso123 , 15.06.2019 17:06
Hallo Stummi Freunde !!
After some months in which I was busy and far away from home, I restarted the layout activities with much more progress on it.
Finally the different levels were defined and all ramps adjusted and tested succesfully !!
Now its time to complete all electrical connections from turn outs and contact tracks to S88.
The final descending ramp to the yard is not connected since I´m still working on it.
Here are some pictures of the progress.
Hope you enjoy them !!
Here is a short video with the first test of levels +1 and +2
https://youtu.be/o2kkqKGrvj4
Die Gleiswendel zum Bahnhof der Ebene + 2 auf der Westseite, und detail der unteren Bereiche
Anordnung der S88-Module und des Decoders für die Weichen
Detail der Schattenbahnhof. Insgesamt gibt es 11 Gleise mit einer Stufe.
Allgemeine Ansichten
Ansichten der Ostseite des Moba
Blick auf die Gleiswendel auf der Westseite
Detail des Zugangs zur Schattenbahnhof auf der Ostseite
Detail der letzten Zugangsverbindung zur Schattenbahnhof. Verbindungspunkt.
Detail Schattenbahnhof
Detail des Schutzes gegen Stürze des Materials
carleso123
carleso123
#14 von carleso123 , 19.06.2019 12:13
Guten Morgen
Dies ist das Design des Abschnitts, der mit der Schattenbahnhof verbunden wird.
Wie Sie sehen, durchlaufen alle Umläufe diese drei Elemente, sodass einige Züge umlaufen und die obere Bahnhof auf der rechten oder linken Seite erreichen können.
Ich würde gerne Ihre Meinung dazu erfahren.
Halten Sie ein solches System für ratsam?
Endgültige Gestaltung des Anschlusspunktes
Unten rechts der Verbindungspunkt der Gleiswendel zur Schattenbahnhof.
Vielen Dank für Ihre Kommentare.
Carles.
carleso123
carleso123
