RE: Roco iodore 59750 Two motors are opposed
#1 von Penguinator ( gelöscht ) , 30.06.2018 18:54
Help after being in the box for years, double locomotive did not run. Finally got it running, probably the kopplung. Engines run in opposite direction with the locomotive stationary without lights.
Any ideas? Thanks
Penguinator
#2 von X2000 , 30.06.2018 21:01
Yes, change the wiring on one of the motors.
X2000
X2000
Gleise C
Spurweite H0, H0m, Z, 1
#3 von Derrick23 , 09.07.2018 21:49
The easiest way seems to be to just rotatet the motor by 180 degrees, this should alter the direction of rotation!
Derrick23
Derrick23
Registriert am: 13.08.2006
Gleise Roco Line
Steuerung TwinCenter
